how to determine angle between 2 planes
11584.6 In reply to 11584.4
Hi Dan,
Re:
> Is it possible to snap a line segment starting at and perpendicular to a
> point on the helper line and ending at another point on the surface of
> one plane, then beginning at the same point on the helper line, snap a
> line segment also perpendicular to the helper line to another point on
> the surface of the second plane?
That will work if the planes are joined along an edge. Then you can snap perpendicular to the edge. Both Straight Snap and Object Snap need to be turned on. Doesn't work for 2 disconnected planes and an intersection line though.
Re:
> Also is it possible to use DIM angle command to derive the measurement
> of this angle?
No the Dim Angle won't end up on the correct plane. You'll need to align the construction plane coordinate system with the edge and one of the object planes using Cplane. Depending on the situation you might need to draw a helper line perpendicular to the edge to have something to snap the Cplane orientation picker to.
http://moi3d.com/4.0/docs/moi_command_reference11.htm#orientationpicker
Starting out with neither plane aligned with world coordinates:
Activate the Cplane command:
Align the orientation picker to the edge and one of the planes:
Now the Dim angle tool can be used in one of the ortho views:
- Peer
EDITED: 17 Nov 2024 by PEER
