v4 CustomUI
11576.2 In reply to 11576.1
Hi Raven, the CustomUI .zip file is named CustomUI.2.0.beta2.zip .
When you unzip it, there will be 3 folders, "customui", "objects", and "startup".
These need to be copied into the MoI app data folder.
You can open the MOI appdata folder by typing Win+R to bring up the windows "Run" dialog and type in %appdata%\Moi that will expand to a folder like C:\Users\<Your user name>\AppData\Roaming\Moi
Copy the "customui" and "objects" folder from the .zip file into there, so you have %appdata%\Moi\customui and %appdata%\Moi\objects.
Then for the "startup" folder there will already be a folder for that in appdata so go into the startup folder from the .zip and copy all the contents of it into the already existing %appdata%\Moi\startup folder.
