Using Sweep on corners
11571.5 In reply to 11571.4
Hi Billabong, also another possible technique is to do a sweep in 2 passes using 3 profile curves with the middle one slanted like this:
The pieces then will touch at their ends so they can just be joined with no extension and intersection needed.
The problem with that method is that the surface won't be an exact tube with a precise circular cross section at all points along the rail, the shape mutates a little bit as it travels along the rail and transitions from the circle profile to the slanted profile.
That's why sweep doesn't use that method currently but I would like to make it an option.
