Using Sweep on corners
11571.2 In reply to 11571.1
Hi Billabong,
> I first tried sweeping it with the rails joined. but that gave me this issue:
In one-rail sweep when there is a sharp corner in the rail it will attempt to do mitered corners by extending the sweep surfaces and trying to intersect them with each other. The intersection part gets much more difficult when the sweep rail is not a planar curve.
In that case it will leave the extensions so there is something to work with.
> So then I tried the method that is in the link above, but when I do, it corrupts
> the vertical sweep and does not trim the horizontal one:
This kind of messy result means there is some problem with the trim curves. Probably if you zoom in to where the curves look like they are crossing each other there will be some kind of anomaly there.
Your objects are at a rather small scale, it could help if you would scale them up by say 100x.
