Hi halmi,
> This is what's happening in an unpredictable fashion in my workspace.
To avoid that you need to set the rotation pivot point as described above.
When you want to orbit around a particular object, select it and push the "Reset" button.
If you want to work closely on a small area of an object either select an edge or face in that area and push Reset or use the Area zoom button to snap on to a specific point.
In your video the problem is that you're not using either one of those methods.
