Extrusion issue
11535.2 In reply to 11535.1
Hi Rik, creating a new surface by displacement along surface normals (as opposed to a single overall direction like Extrude) is done with the Construct > Offset command.
You can also use Construct > Offset > Shell which will also construct side walls.
If your surface is kind of wiggly though an offset can be problematic since wiggles will get magnified.
If you could post a .3dm file with your surface in it, that could help to give other advice.
EDITED: 13 Sep 2024 by MICHAEL GIBSON
