beta 5 dimension question?
11527.4 In reply to 11527.1
Hi Scott, that's normal behavior which stems from the line not being parallel to the view plane.
Dimensions are associated with a projection plane which they get from the view that you create them in. The length that they show is a length of the endpoints projected onto that plane, not a 3D distance like the curve length is generating.
That dimensioning behavior in CAD programs is inherited from hundreds of years of drafting conventions.
In drafting it is not allowed to display distances as measured in 3D space.
The reason why is that in drafting, a dimension is supposed to be a label that can be verified by a manual measurement on the drafting table. When you go to make a measurement by using a ruler on the drafting table, you can only get a 2D distance there.
It kind of sounds like you were expecting horizontal and vertical dims to display a different value than the 3D distance but not "Aligned". But all 3 of these commands behave the same in that they have a projection plane and the distance that is displayed is the distance in that plane.
EDITED: 6 Sep 2024 by MICHAEL GIBSON
