Hi PILOU
The extrude part can be skipped by setting the last command parameter to true.
code: edgeFlange 5 true false 4 Auto 1 false true
code: edgeFlange 5 true true 4 Auto 1 false true
This way you can repeat the 'edgeFlange' command by right click.
But if you like to run the extrude command at the end, It will change the last executed command to 'extrude'. That's why right click repeats the extrude command.
Another option is to set a shortcut key for 'edgeFlange' command and run it from there.
