PDF Export Scaling
11511.3 In reply to 11511.2
Hi Michael, I guess we could see equal padding is the result from scaling and reducing the scale factor proportionally so yes we’re on the same page I think.
If you look at page 1 of the pdf I sent you that is an example on a landscape pdf where the portrait type object is about 20/25% too tall THEN If you look at page 4 you might with your skills find my trick 0.5mm dot in the pdf somoewhere…I put this above the main moi object and it reduced the scale - but I think that dot works more as a “top pad” because the object is still quite far down the pdf page. Padding would be ultimate control I guess but proportional scaling is still going to help - a lot.
I just need a bit more control on the pdf output position and/or size. Anything you see as doable is appreciated.
