PDF Export Scaling
11511.1
Hi Michael in previous posts / discussions I indicated would be great to have some workflow based pdf features. Mainly as it seems it’s the best way to get sharp vector visualisations.
On expirementing with a workflow where I am deliberately not trying (or wanting) to re-edit any moi export pdfs in acrobat, Corel, or any other pdf editor I have found a very simple way to work.
For me currently, there is one major limitation with the pdf export which I found a workaround for but feel you can solve easily…
if I decide to say export 15pdfs from one moi drawing to create a presentation and I’m using pdf software to put a “watermark”
behind these pdf pages - then if I put “fit to page” in moi the graphics/pdfs and I then merge all these pdfs using a simple pdf merge tool then moi output can often be a bit too too tall or bit too wide.
Can I please ask for a valid feature to be added to the pdf export window, we need to have “fit to page” but allow users to set a maximum % of the fit or allow a padding value?
I found a workaround to put a tiny dot above the graphic
which is about 0.5mm this is selected as an export object and not visible on the pdf rendered but it proportionately reduces the output graphic size.
