ACIS kernel in MoI V5
11508.2 In reply to 11508.1
Hi mdesign, welcome back to the forum!
> Could you tell me when could I expect final release of v5 (to buy upgrade)?
> I will buy it with pleasure.
I don't have a firm date set yet but hopefully not too long. Maybe a few more months.
> Will it be possible to use ctrl+c ctrl+v between MoI3d v5 and Rhino v8?
No not by default because unfortunately with every new release Rhino drops support for versions lower than the previous one for copy and paste.
So Rhino v8 can only read a v7 3DM file from the clipboard even though it is able to load all earlier .3dm versions from regular File > Open.
However I set up a utility program that can convert a .3dm file in the clipboard between v5 and v7 formats so it's then possible to make copy/paste work by running the utility program when doing ctrl+c or ctrl+v.
You can get that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9890.18
> What modeling commands will have ACIS kernel behind?
Currently it's on the Fillet and Chamfer commands. I also want to use it for some other things like offset, shell, and direct modeling face transforms but those may not happen in the MoI v5 time frame, not sure yet.
EDITED: 10 Aug 2024 by MICHAEL GIBSON
