collinear line segments
11507.3 In reply to 11507.1
Hi Salvatore,
> if i just select everything and launch the command Join, it will also convert connected
> lines into Polylines, which is something I don't want.
If this is the only problem you could do Join, then Rebuild, then Separate at the end to break apart the polylines.
If you don't want to have anything happen to already existing polylines, select only lines before doing the initial Join.
You can select lines in v5 in the scene browser under Types > Curves > Lines. Or a second method is to use the selection narrowing mechanism in the "Details..." object properties dialog. For that one select all then open "Details..." and in the "Types" report section that lists the various types of the current selection click the "X lines" tag.
