collinear line segments
11507.1
Hi all,
Does anybody know a quicker way to clean up 2D drawings where there are lots of lines made of single segments?
Initially I was using the Join command followed by Show Points, and then select and delete the points in the middle. Then I found out that was better to do a Rebuild after Join.
By the way, the annoying part is that I have to select the single lines, which is quite time consuming, because if i just select everything and launch the command Join, it will also convert connected lines into Polylines, which is something I don't want.
Any ideas or possible script?
Thanks!
Salvatore
