Hi Tim, yes so that is some customized UI.
I think the script for it is probably located in this folder:
~/Library/Application Support/Moi/startup/
And probably called something like "84 Snapshot.js", do you see it there? If it's an older version it might be in a different spot though.
What happens if you right click on the button instead of left click? I think that particular script may have been set up to show grid on left click and hide it on right click.
Also if you hold down Ctrl and/or shift when you click it will also do a slightly different size or color variation.
