Export Filled Surfaces as PDF?
11478.1
I am trying to use MOI (V5 Beta) to create a template for a clock dial. I want to print it out either to use as a mask for photo etching, or to make a waterslide decal which can be applied.
I have successfully created the template, using planar surfaces to create the roman numerals and indices round the edges. However when I try to export the resulting set of surfaces as a PDF for printing, all I get are the edges of the surfaces rather than the solid filled surfaces. I have (I think) tried all the options in the export dialogue, but nothing seems to want to export the filled surfaces.
Am I being thick ( not unusual) or is there no simple way to do this. If its the former, could someone point me at my error. If the latter can someone suggest a workflow that would work.
