Make2D - Isometric View Not to Scale
11475.1
I often use the MAKE2D OR MAKE2D4VIEWS command to generate technical drawings for presentations.
When I make a 2D drawing from a Top, Front or Left view, the result is a 1:1 scale drawing projected on the TOP view, which is great. However, when I make a 2D from a 3D view set as isometric (REF: https://moi3d.com/forum/index.php?webtag=MOI&msg=1917.35) the result is always a drawing that is 81.63% smaller than the correct dimension. So I have to apply a scale factor of approx. 1.225 to get the correct size.
To be honest, this is not a major issue as I can easily scale the drawing, however I wonder if there is a reason why I get this specific result.
