Odd issue with circular array and boolean
11474.2 In reply to 11474.1
Hi Gunter,
The problem is caused by the ovals having an edge that is very close to being coincident with the surface of the ring:
I moved one of the ovals that wasn't working away from the ring slightly:
and boolean diff worked fine then.
I don't get the deformed oval like you show. For whatever reason, that one actually worked ok for me. But, it's generally a bad idea to have surfaces or edges just grazing one another for booleans. Just like a surface has edges, some curves have points where they are joined and those points can also cause problems if they are very close to lining up with an edge or a point on the other object in the boolean.
- Peer
