Installing Custom UI
11472.2 In reply to 11472.1
Hi Gunter, so it looks like it isn't quite set up right.
When you unzipped it, the files went into a subfolder "Moi/CustomUI.2.0.beta2"
If you look inside of that folder you should see 3 subfolders "customui", "objects", and "startup" like this:
Moi/CustomUI.2.0.beta2/customui
Moi/CustomUI.2.0.beta2/objects
Moi/CustomUI.2.0.beta2/startup
Copy the "customui" and "objects" folders up one level so they are directly under the Moi folder, like this:
Moi/customui
Moi/objects
Then unlike those 2 folders, there is an already existing startup folder in Moi/startup.
Copy the contents of the Moi/CustomUI.2.0.beta2/startup into Moi/startup and then you're done.
> Not sure what is meant by: After installation remove all unneeded .js scripts from startup directory
> So I deleted all of files in the start up folder.
Just ignore that part and do not delete any files from the startup folder.
Then restart Moi and you should see new buttons on the bottom toolbar.
