Flow Target surface issue
11471.7 In reply to 11471.2
Thank you for explaining this Michael, I followed your advice and got the same result as in your screenshot.
To remedy this, I deleted the upper quadrant surface and then mirrored the opposite sides upper quadrant. On the assumption that the opposite side also had the splitting issue, would the best way forward be to delete the top surfaces are rebuild them or is there a more efficient method?
