Flow Target surface issue
11471.4 In reply to 11471.1
Hi Gunter
Here is a file back where I did a flow and enabled History on it.
If you enable points on the target then look at points on the base.
You can then adjust the base width and watch the results update.
This can give you a good view of what is happenoing with it and help your future endeavors.
I can do a video to explain if this is unclear.
