When using Flow, target surface splits
11466.7 In reply to 11466.1
HI gunter
请在操作步骤的的基础上增加类似这样的工序。(Please add a process similar to this on top of the operational steps.)
这是因为moi的join和boolean union无法在所有的情况下都形成surface在这篇讨论中:http://moi3d.com/forum/messages.php?webtag=MOI&msg=11426.1 有相应原因的说明。
This is because the join and Boolean union of moi cannot form a surface in all cases. In this discussion There is an explanation for the corresponding reason.
因此你需要在完成圆环的缝合曲面后,提取边缘和曲线,再一次进行扫略,让曲面变得完整。
Therefore, after completing the stitching surface of the torus, you need to extract the edges and curves, and then perform another sweep to make the surface complete.
