When using Flow, target surface splits
11466.2 In reply to 11466.1
Hi Gunter,
> in this example once I click on the object, then base surface and then target surface,
> it seems to 'trim' the target surface in 2:
It's because your target surface is made up of 2 surfaces that are joined together, it isn't just one large single surface.
> I tried redoing the surface a few times but each time it splits it.
Could you please give some details and a file for how you tried to redo the surface?
The reason why it would be split up kind of depends on the method used to construct it. It could be something like your construction curves are also split into multiple segments instead of being one single segment, or segments that have a slight crease between them instead of being smooth where they touch.
One other thing to note, if you make the base surface hug the object more closely then you could use the Projective mode for flow in this case, projective mode can use a joined surface as the target instead of only a single surface:
