Import 3dm Rhino file for Blender
11463.3 In reply to 11463.2
“””””” I did some tests but the 3dm files saved with Moi3D surfaces are not imported while those saved with RhinoV5 are imported correctly,and wonder why?”””””
Rhino uses a concept of saving the “display render mesh”
They arent using NURBS. It is basically a polygon model
MoI does not save this mesh data in a 3dm.
You should be able to get the same results if you do a “save small” in rhino. This drops out the render mesh to save on file sizes.
