Side panels closed when opening a project
11461.1
Hello,
For the past 1-2 months, the panels on the side of the UI have been closed whenever I open a 3dm file. I initially thought this was a template file issue, but modifying the template did not resolve the problem.
I don’t believe I accidentally changed any settings, but if that is the case, I would appreciate knowing which setting could be causing this issue.
Thank you!
Size: 27.8 KB, Downloaded: 69 times, Dimensions: 320x540px
