Problems with loft and boolean in a faceted object
11451.6 In reply to 11451.1
Hi Gunter,
> I'm making this faceted gemstone with a somewhat unusual shape. I'm not happy
> with the way the geometric section lofts to the more rounded section:
Could you maybe describe a little about what it is that you're not happy with?
One thing you may want to do is instead of doing the loft between 2 long curves instead divide up the smooth curve and do a separate loft for each separate straight piece to a curved piece. You'll then be controlling how the sharp to smooth shapes merge together instead of using the default merging.
> I was wondering if there's another option to lofting?
Well if you put in lines from each sharp point down to the smooth curve or do it in sections you could also do sweep or network instead of loft.
