Problems with loft and boolean in a faceted object
11451.2 In reply to 11451.1
HI gunter,首先你的上半部分是join srf+soild,所以不能布尔运算(First of all, your upper part is a join srf+soil, so it cannot perform Boolean operations)
放样效果很不理想,我想可能是两方面原因,我发现你最上端的线框,线被分为两部分的,你可能直接选择了三个部分的线进行了放样,这样在moi是会出现无法形成理想结果。
(The loft effect is not ideal, and I think it may be due to two reasons. I found that the line at the top of your wireframe is divided into two parts. You may have directly selected three parts of the line for loft, which may result in an unsatisfactory result in Moi.)
还有可能你所绘制的线框和你的实体的上表面边缘,不是完全重合的(It is also possible that the wireframe you draw does not completely overlap with the upper surface edge of your entity)
应该这样选择边缘,使用join,再看它们的是不是封闭的曲线(You should choose the edges this way, use the join, and then check if their curves are closed)
放样,如果结果是实体,那么可以进行布尔合并,结果很好(loft, If the result is an entity, then Boolean union can be performed, and the result is good)
对于这种切割模型,迈克应该会推荐这种方式。挤压形成达到高度的实体,然后将用于需要切割的封闭曲线挤压成工具实体,进行布尔差集
(For this cutting model, Mike should recommend this method. Squeeze to form a solid that reaches a height, then squeeze the closed curve used for cutting into a tool solid, and perform Boolean difference set)
