Make2D Hidden lines Style and Color
11450.8 In reply to 11450.7
Hi Mo,
thank you for your reply.
You are right, that's possible to use vector program like Inscape to set the line style, I personally use Affinity Designer2, but it would be nice to have such possibility inside MoI, especially if such settings - Line Style Options dialog exists already for MoI objects.
I use DashCurve script for Hidden lines too, it works perfect, but for many technical drawings, which I has to do from assembly contained many parts, so every repeatably line settings inside/outside MoI cost some time.
It would be ideal for me after check Generate hidden checkbox, if Make2D4views script would generate dashed hidden lines with color of Style = #000000 in one step, then PDF export with white surface as a background of technical drawings works OK.
MoI PDF export settings works perfectly for objects, therefore I'm sure that next beta allows similar line style settings for visible/hidden curves (wireframes) as Michael posted.
Mik
