Yes, and Style named "Hidden lines" is associated with white color after run the script. Is it possible to change this white color to be same as visible lines?
I know that I can edit color of style, but it save some time for many technical drawings.
Regarding dash lines....
I know, that MoI cannot control Style of lines, but when I export objects as PDF, so I can control color and the appearance of dash line of Hidden lines in Line Style Options dialog.
When I export the Hidden Lines as a PDF from Make2D/Make2D4views command I have to change the color of Style named Hidden Lines manually, because white color cannot be print on white paper and settings in Line Style Options dialog doesn't affect Style of hidden lines.
I can use DashCurve script for changing of style of any curve, of course, but I thought that Hidden Lines have special atribut in Moi and therefore settings in Line Style Options dialog in PDF export can affect the appearance of lines.
Thank you for your time.
Mik
