Doming object on surface
11449.10 In reply to 11449.9
Hi Gunter,
> Is it to just restrict the lattice from stretching?
Yes, because in surface-to-surface flow mode it will match the entire base surface to the entire target surface.
> Why is this not needed when you use curves as I did before?
Curve-to-curve flow has a "stretch" option that you can turn on or off unlike surface-to-surface flow.
In curve-to-curve flow when "stretch" is off it will match distance traveled along the curves. But it's difficult to have that type of matching in surface-to-surface flow because there isn't just one direction anymore, a surface can easily stretch or compress to different widths at different spots along it.
