Bending objects / surfaces
11447.8 In reply to 11447.6
Hi gunter,
> I tried flow but with projection on curved surface but I'm getting aberrations - pls see attached screenshot.
Projective flow will send out rays along the surface normals of your base plane and try to intersect the rays with the target object.
If some of these rays do not intersect with the target object you can get the kind of aberrations you show there.
To use projective flow mode you would need to make your target object extend to be wider so that every point on the base plane will hit the target object.
