Line thickness when exporting
11446.1
Hi there,
I'm sorry to bother you, but I noticed a small issue with beta 5 when exporting to PDF. If there are no surface objects in the space, but only lines, the line width cannot be adjusted and the lines end up being very bold. However, if you add a surface object, the setting appears.
Is it possible to have the line adjustment option appear when exporting even if there are no surface objects?
Thank you for your help!
Size: 215.8 KB, Downloaded: 89 times, Dimensions: 3763x772px
