Hi Andre, try setting up a shortcut key with BoundingBox as the command name.
Then select your object and trigger the shortcut key to make a bounding rectangle.
Select the bounding rectangle and then run Construct > Offset and type in your minimum distance value and click a point on the outside of the box to control which direction it will use.
