Unable to create a solid
11430.2 In reply to 11430.1
Hi Gunter, some of the facets are 4 sided regions but they are not planar, so that's why Construct > Planar isn't able to do anything on those.
Probably the easiest way to generate it without tuning up it up to be all planar would be to use join together these pieces to make 2 closed curves:
Then use Construct > loft which will build about half of it like this:
Now join these 3 pieces:
And these 3 pieces:
And then Construct > Loft between those 2 curves to get this:
Repeat that on the other side and use Edit > Join to glue it together into a solid.
