制作足球-一个关于布尔和并曲面的问题(Why does using Boolean union to merge surfaces produce different results?(surface or joined srf))
11426.8 In reply to 11426.7
Hi SUIYAN, for now you would be able to get more pieces to merge if you take care that their initial starting spheres were the same.
If you want to mirror or rotate a piece, do that on your curves but not the surface and then trim the one common surface with the transformed curves.
Pieces constructed in that manner will be able to merge.
