Joining and Filleting
11417.4 In reply to 11417.1
Hi Gunter, also there is a plugin that could help here which can extend surfaces:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9747.7
I made the attached version by using that FlowExtendSrf plugin to lengthen the surfaces like this:
Using FlowExtendSrf:
After the surface extension, these 3 surfaces need to be retrimmed with these edges:
Then use Edit > Join to glue all the top object's surfaces together and then the top and bottom can be combined using Trim or also Boolean Union.
EDITED: 29 May 2024 by MICHAEL GIBSON
