Scripting the Trim command -- programmatically select objects to keep or remove?
Michael Gibson
30 May 2024 (9 of 9)
11415.9
In reply to
11415.8
Hi Mike, clearing selection lock is something that normally happens when a command ends.
When you run a startup script it's not using the "command" mechanism and so you'll have to do some things manually like that.
