Scripting the Trim command -- programmatically select objects to keep or remove?
11415.6 In reply to 11415.5
Hi Mike,
I can click on the circle fine in v4 and in v5.
Is the code that you posted the entirety of your script, or is there other code too? Is there anything going on in the companion .htm file?
It sounds like selection lock is getting set on the circle. That's the typical reason for not being able to click on something.
- Peer
