Help with finishing curved radiused ramp transitions.
11407.1
I'm after some advice on how to complete the 'down ramp' section of this model. I'm trying smooth out the sharp transition at both the top and the bottom of the 'small ramp' section on this cam. I need a 1mm curved transition at the top and a smoother 2mm curved transition at the bottom.
I'm having trouble drawing the transition edge lines to network while keeping the inner and outer radius correct. I tried using the curve-project command to match the radius but not sure how to implement it in this instance.
Any help or direction appreciated.
