Boolean
11406.3 In reply to 11406.1
Hi Booleano, another possible method other than Transform > Deform > Flow woud be to use boolean difference to cut the shape at the line where you want the bend:
Then these now separate pieces can be rotated by 90 degrees using Transform > Rotate > Rotate Axis:
You'll then need to create some surfaces to fill in, using Blend is one possible way:
