bug?
11398.1
Michael,
I may have found a bug. If I fillet with solid++ on the the two bottom edges and then export out to STEP the model is fine but when I fillet with ACIS and export out to STEP the file becomes corrupt. If you bring the two step files back into moi they both are solid but you can see it is failing in the ACIS. the ACIS also fails in 123D Design and Plasticity. the Solid++ is fine.
I've attached a moi file with the two models named to the fillet type and the two step files also named to the fillet.
thanks,
Val
