STEP export
11386.2 In reply to 11386.1
Hi Don, what are you using to make the file, is it "File > Save As" or "File > Export" ?
The difference between these is that "File > Export" writes only the selected objects to the output file, while "File > Save As" will write everything regardless of selection.
So what you describe would be normal behavior if you had only the text objects selected and did a File > Export.
Please let me know if that doesn't explain it.
