Hi Robert, there is a "Rigid" checkbox option in the Flow command for doing that:
When that option is enabled only the center point of the object's bounding box is morphed and the object is rotated and moved only, not deformed.
Note that will not necessarily mean that the objects will be spaced equally apart from each other though, for that you may need some more specialized Pavé type tool with some jewelry specific plugins for Rhino.
