Import obj/fbx into MoI with zero subdivisions...
11379.2 In reply to 11379.1
Hi Rich,
> Is there a way to bring in an obj/fbx into MoI with zero subdivisions using the Create command?
No, the SubD > Create > From File method is focused on converting the sub-d "limit surface" to NURBS geometry.
Zero subdivisions would result in polygons, not a smooth surface and MoI is not focused on polygon modeling.
There is a converter here which you can use to convert polygons to wireframe lines that you can bring in though:
http://moi3d.com/resources#Obj23dmWireframe_converter
