MINIMUM ANGLE DEVIATION BETWEEN 2 LINES TO APPLY A FILLET
11368.2 In reply to 11368.1
Hi Alex,
> Just wondering what is the tolerance for MOI to judge what is the minimum deviation angle
> from a straight line to which the mid point a fillet can or cannot be applied to
Filleting doesn't make a decision to bail out based on an angle measurement.
But as the angle gets smaller and smaller, the fillet arc will get very tiny and at a certain size level it will either fail to generate a minuscule arc or the solver mechanism will fail to converge.
The specific threshold where that will occur will likely depend on several factors like the size and location of the lines and the fillet radius.
I did a quick test over here and I was able to go down to an angle of 0.0001 degrees ok.
