MINIMUM ANGLE DEVIATION BETWEEN 2 LINES TO APPLY A FILLET
11368.10 In reply to 11368.9
Hi Alex, so you can probably get the missing one by using Edit > Separate on the polyline and then selecting the 2 separate individual lines there as the input to Fillet.
When fillet is given 2 separate curves that's when there isn't an angle limit used.
The fillet piece will be very small though when the the lines get close to colinear.
