Script to Batch Convert STEP to FBX
11365.1
Hello everyone,
I use Moi exclusively for converting STEP files to FBX to use them in Blender as I found the Mesh to be very good. When exporting, I almost always use the same settings. So I had the idea to speed up the whole process with a script and started to work with scripts in Moi. Unfortunately, it's difficult to find resources on the subject. The scripting part is not really well documented for my taste.
Anyway, I wanted to ask if it would be possible to write a script that doesn't even require starting the Moi UI. I was thinking of a shortcut on the desktop where I drag and drop my files to be converted. Then only a console opens (or maybe nothing at all) and the files are batch processed and exported as FBX files to the same location as their original step files.
If this does not work, is it possible to open an exporter window with a script in which I can select the step files?
Thanks for any help
