Blending
11361.4
That worked very well. Thank you very much, Michael!
I tried to reproduce your described correction (via "rebuild" command) but I had to fall back to your version because it must be something else. But never mind.
Good - in principle I'm almost there.
However, the placement using FlowTool is not quite successful yet. I can't connect the components with each other. Although it actually looks good.
What is the tiny detail here that prevents it from coming together?
Cheers, Mala
