Specific model and general milling preparation questions ?
11353.5 In reply to 11353.1
Hi Sven,
The most important thing to give a shop is a good 2D drawing with dimensions, tolerances, material, and surface finish all spelled out. A machinist can't tell from a 3D model what your intent actually is. It's not possible for them to machine the ideal "platonic" version of your model, so they need to know how much they're allowed to deviate on each feature.
That said, some shops will accept just a 3D model, an overall tolerance, and an overall surface roughness. But if there's no drawing and you don't like what they deliver it will be difficult to get them to fix it.
Re:
> high-density polyethylene
As you might have found, that's a difficult material to mill. In some ways worse than the hardest steels because it requires razor sharp tools and gentle clamping since it's both soft and tough.
I would try to find a very small (1 man) shop that's close enough to you that you can go there and talk it over with them in person. That way they can give you feedback on the design and you can fully describe what the important areas of the part are.
Finding a good machine shop can be pretty difficult.
Re:
> I appreciate when people create posts with animated gifs
> showing what they are looking for or before and after.
LICEcap is a good program for Mac. Not sure about what's out there for Windows.
- Peer
