Hi Sven, so typically the main thing that shop will likely be looking for is to have the model be a closed solid object.
Usually to fill in the triangular area you show you would use Construct > Planar. But this case here is having some problem with that so instead you can use Draw solid > Plane to put in a rectangular plane and then use the Edit > Trim command to cut the plane.
