General menu versus Dimensions menu
A note on Options menu, versus Dimensions menu, observed when drafting an old deck for refurbishment:
The Options > Dimensions > menu shows >Formatting: as a separate section, separated with top and bottom faint lines.
(Which looks very nice.)
The Options > General > Unit system:
> Distance display:
> Fractional display:
> Decimal display:
is not separated by the faint lines. Since the 4 settings are related, it might be nice to format them similarly to the Dimensions method???
It is nice to have the Dimensions formatting separate from the General settings, in case the user likes decimal vs Feet & Inches, for viewing dimensions, or the user can set both formats to be the same.
Previously placed dimensions do not change their display format, in the event the master formatting is changed, which is OK, IMHO. (AFAIK)
Here in the USA, carpenters nearly always use feet & inches & fractions of inches, instead of Metric. I finally found a (half) metric tape measure at the hardware store. :-)
